A One-Time Truncate and Encode Multiresolution Stochastic Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
In this work a novel adaptive strategy for stochastic problems, inspired to the classical Harten's framework, is presented. The proposed algorithm allows building, in a very general manner, stochastic numerical schemes starting from a whatever type of deterministic schemes and handling a large class of problems, from unsteady to discontinuous solutions. Its formulations permits to recover the same results concerning the interpolation theory of the classical multiresolution approach, but with an extension to uncertainty quantification problems. The interest of the present strategy is demonstrated by performing several numerical problems where different forms of uncertainty distributions are taken into account, such as discontinuous and unsteady custom-defined probability density functions. In addition to algebraic and ordinary differential equations, numerical results for the challenging 1D Kraichnan-Orszag are reported in terms of accuracy and convergence. Finally, a two degree-of-freedom aeroelastic model for a subsonic case is presented. Though quite simple, the model allows recovering some physical key aspect, on the fluid/structure interaction, thanks to the quasi-steady aerodynamic approximation employed. The injection of an uncertainty is chosen in order to obtain a complete parameterization of the mass matrix. All the numerical results are compared with respect to classical Monte Carlo solution and with a non-intrusive Polynomial Chaos method.
RR-7967.pdf (13.31 Mo) Télécharger le fichier
hal-00699026 , version 1 (18-05-2012)
hal-00699026 , version 2 (31-08-2015)
  • HAL Id : hal-00699026 , version 1
Remi Abgrall, Pietro Marco Congedo, Gianluca Geraci. A One-Time Truncate and Encode Multiresolution Stochastic Framework. [Research Report] RR-7967, 2012. ⟨hal-00699026v1⟩
340 Consultations
294 Téléchargements
