Using Symmetries in the Index Calculus for Elliptic Curves Discrete Logarithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Jean-Charles Faugère
Louise Huot
  • Fonction : Auteur correspondant
  • PersonId : 925468
Connectez-vous pour contacter l'auteur
Guénaël Renault
In 2004, an algorithm is introduced to solve the DLP for elliptic curves defined over a non prime finite field $\F_{q^n}$. One of the main steps of this algorithm requires decomposing points of the curve $E(\F_{q^n})$ with respect to a factor base, this problem is denoted PDP. In this paper, we will apply this algorithm to the case of Edwards curves, the well known family of elliptic curves that allow faster arithmetic as shown by Bernstein and Lange. More precisely, we show how to take advantage of some symmetries of twisted Edwards and twisted Jacobi intersections curves to gain an exponential factor $2^{3 (n-1)}$ to solve the corresponding PDP. Practical experiments supporting the theoretical result are also given. For instance, the complexity of solving the ECDLP for twisted Edwards curves defined over $\F_{q^5}$, with $q\approx2^{64}$, is supposed to be $2^{160}$ operations in $E(\F_{q^5})$ using generic algorithms compared to $2^{127}$ operations (multiplication of two $32$ bits words) with our method. For these parameters the PDP is untractable with the original algorithm. The main tool to achieve these results relies on the use of the symmetries during the polynomial system solving step. Also, we use a recent work on a new strategy for the change of ordering of Gröbner basis which provides a better heuristic complexity of the total solving process.
FGHR2012.pdf (295.85 Ko) Télécharger le fichier
hal-00700555 , version 1 (23-05-2012)
hal-00700555 , version 2 (29-03-2013)
hal-00700555 , version 3 (18-06-2013)
  • HAL Id : hal-00700555 , version 1
Jean-Charles Faugère, Pierrick Gaudry, Louise Huot, Guénaël Renault. Using Symmetries in the Index Calculus for Elliptic Curves Discrete Logarithm. 2012. ⟨hal-00700555v1⟩
716 Consultations
788 Téléchargements
