Surface Flows for Image-based Shading Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2012
We present a novel method for producing convincing pictures of shaded objects based entirely on 2D image operations. This approach, which we call image-based shading design, offers direct artistic control in the picture plane by deforming image primitives so that they appear to conform to specific 3D shapes. Using a differential analysis of reflected radiance, we identify the two types of surface flows involved in the depiction of shaded objects, which are consistent with recent perceptual studies. We then introduce two novel deformation operators that closely mimic surface flows while providing direct artistic controls in real-time.
paper.pdf (2.32 Mo) Télécharger le fichier
c99-f99_2-a563-suppvideo-v1.flv (36.88 Mo) Télécharger le fichier
supmat.pdf (43.98 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Autre
hal-00702280 , version 1 (29-05-2012)
hal-00702280 , version 2 (04-09-2012)
  • HAL Id : hal-00702280 , version 1
Romain Vergne, Pascal Barla, Roland Fleming, Xavier Granier. Surface Flows for Image-based Shading Design. ACM Transactions on Graphics, 2012, 31 (3). ⟨hal-00702280v1⟩
1757 Consultations
1494 Téléchargements
