DiaSuite: a Tool Suite To Develop Sense/Compute/Control Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2014
We present DiaSuite, a tool suite that uses a software design approach to drive the development process. DiaSuite focuses on a specific domain, namely Sense/Compute/Control (SCC) applications. It comprises a domain-specific design language, a compiler producing a Java programming framework, a 2D-renderer to simulate an application, and a deployment framework. We have validated our tool suite on a variety of concrete applications in areas including telecommunications, building automation, robotics and avionics.
diasuite.pdf (1.25 Mo) Télécharger le fichier
hal-00702909 , version 1 (31-05-2012)
Benjamin Bertran, Julien Bruneau, Damien Cassou, Nicolas Loriant, Emilie Balland, et al.. DiaSuite: a Tool Suite To Develop Sense/Compute/Control Applications. Science of Computer Programming, 2014, Science of Computer Programming, 79, ⟨10.1016/j.scico.2012.04.001⟩. ⟨hal-00702909⟩
Collections
CNRS INRIA INRIA2
534 Consultations
2159 Téléchargements
