DiaSuite: a Tool Suite To Develop Sense/Compute/Control Applications
We present DiaSuite, a tool suite that uses a software design approach to drive the development process. DiaSuite focuses on a specific domain, namely Sense/Compute/Control (SCC) applications. It comprises a domain-specific design language, a compiler producing a Java programming framework, a 2D-renderer to simulate an application, and a deployment framework. We have validated our tool suite on a variety of concrete applications in areas including telecommunications, building automation, robotics and avionics.
