Applying cross-lingual WSD to wordnet development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The automatic development of semantic resources constitutes an important challenge in the NLP community. The methods used generally exploit existing large-scale resources, such as Princeton WordNet, eventually combined with information extracted from multilingual resources and parallel corpora. In this paper, we show how cross-lingual Word Sense Disambiguation can be applied to wordnet development. We apply the proposed method to WOLF, a free wordnet for French still under development, in order to fill synsets that did not contain any literal yet.
lrec12clwolf.pdf (126.69 Ko) Télécharger le fichier
hal-00703126 , version 1 (31-05-2012)
  • HAL Id : hal-00703126 , version 1
Marianna Ma Apidianaki, Benoît Sagot. Applying cross-lingual WSD to wordnet development. LREC 2012 - Eighth International Conference on Language Resources and Evaluation, May 2012, Istanbul, Turkey. ⟨hal-00703126⟩
170 Consultations
157 Téléchargements
