Modeling Martin Löf Type Theory in Categories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Logic Année : 2014
We present a model of Martin-Lof type theory that includes both dependent products and the identity type. It is based on the category of small categories, with cloven Grothendieck bifibrations used to model dependent types. The identity type is modeled by a path functor that seems to have independent interest from the point of view of homotopy theory. We briefly describe this model's strengths and limitations.
IdentityTypesElsev.pdf (404.99 Ko) Télécharger le fichier
hal-00706562 , version 1 (11-06-2012)
hal-00706562 , version 2 (18-12-2012)
hal-00706562 , version 3 (30-08-2013)
hal-00706562 , version 4 (19-09-2013)
François Lamarche. Modeling Martin Löf Type Theory in Categories. Journal of Applied Logic, 2014, 12 (1), pp.28-44. ⟨10.1016/j.jal.2013.08.003⟩. ⟨hal-00706562v4⟩
327 Consultations
376 Téléchargements
