Gathering an even number of robots in an odd ring without global multiplicity detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We propose a gathering protocol for an even number of robots in a ring-shaped network that allows symmetric but not periodic configurations as initial configurations, yet uses only local weak multiplicity detection. Robots are assumed to be anonymous and oblivious, and the execution model is the non- atomic CORDA model with asynchronous fair scheduling. In our scheme, the number of robots k must be greater than 8, the number of nodes n on a network must be odd and greater than k+3. The running time of our protocol is O(n2) asynchronous rounds.
TechnicalReport.pdf (232.75 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00709074 , version 1 (17-06-2012)
Sayaka Kamei, Anissa Lamani, Fukuhito Ooshita, Sébastien Tixeuil. Gathering an even number of robots in an odd ring without global multiplicity detection. [Research Report] ???. 2012. ⟨hal-00709074⟩
117 Consultations
97 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
