Small time reachable set of bilinear quantum systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This note presents an example of bilinear conservative system in an infinite dimensional Hilbert space for which approximate controllability in the Hilbert unit sphere holds for arbitrary small times. This situation is in contrast with the finite dimensional case and is due to the unboundedness of the drift operator.
Time06.pdf (134.86 Ko) Télécharger le fichier
hal-00710040 , version 1 (07-07-2012)
Nabile Boussaid, Marco Caponigro, Thomas Chambrion. Small time reachable set of bilinear quantum systems. 51st Conference on Decision and Control (CDC), Dec 2012, Maui, HI, United States. pp.1083-1087, ⟨10.1109/CDC.2012.6426208⟩. ⟨hal-00710040⟩
294 Consultations
217 Téléchargements
