A note on the existence of solutions to Markovian superquadratic BSDEs with an unbounded terminal condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2013
In [Stochastc Process. Appl., 122(9):3173-3208], the author proved the existence and the uniqueness of solutions to Markovian superquadratic BSDEs with an unbounded terminal condition when the generator and the terminal condition are locally Lipschitz. In this paper, we prove that the existence result remains true for these BSDEs when the regularity assumptions on the terminal condition is weakened.
superquadraticBSDEs3-HAL.pdf (167.84 Ko) Télécharger le fichier
hal-00713123 , version 1 (29-06-2012)
hal-00713123 , version 2 (15-04-2013)
hal-00713123 , version 3 (15-05-2013)
Federica Masiero, Adrien Richou. A note on the existence of solutions to Markovian superquadratic BSDEs with an unbounded terminal condition. Electronic Journal of Probability, 2013, 18 (50), pp.1-15. ⟨10.1214/EJP.v18-2124⟩. ⟨hal-00713123v3⟩
164 Consultations
222 Téléchargements
