Model-based clustering for multivariate functional data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Statistics and Data Analysis Année : 2014
Julien Jacques
Cristian Preda
  • Fonction : Auteur
  • PersonId : 911328
This paper proposes the first model-based clustering algorithm for multivariate functional data. After introducing multivariate functional principal components analysis (MFPCA), a parametric mixture model, {based on the assumption of normality of the principal components}, is defined and estimated by an EM-like algorithm. The main advantage of the proposed model is its ability to take into account the dependence among curves. Results on simulated and real datasets show the efficiency of the proposed method.
MultiFunclust-Jacques-Preda.pdf (1.36 Mo) Télécharger le fichier
hal-00713334 , version 1 (29-06-2012)
hal-00713334 , version 2 (13-10-2012)
Julien Jacques, Cristian Preda. Model-based clustering for multivariate functional data. Computational Statistics and Data Analysis, 2014, 71, pp.92-106. ⟨10.1016/j.csda.2012.12.004⟩. ⟨hal-00713334v2⟩
582 Consultations
3712 Téléchargements
