Model-based clustering for multivariate functional data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Model-based clustering is considered for multivariate functional data. Based on multivariate functional principal components analysis (FPCA), a mixture model is defined an estimated by an EM-like algorithm. The main advantage of the proposed model is the ability to take into account the dependence among curves, thanks to the multivariate FPCA. Comparisons on simulated and real data show that the proposed method is a good alternative to conventional methods.
Funclust_Jacques_Preda.pdf (1.26 Mo) Télécharger le fichier
hal-00713334 , version 1 (29-06-2012)
hal-00713334 , version 2 (13-10-2012)
  • HAL Id : hal-00713334 , version 1
Julien Jacques, Cristian Preda. Model-based clustering for multivariate functional data. 2011. ⟨hal-00713334v1⟩
583 Consultations
3730 Téléchargements
