A new sliced inverse regression method for multivariate response regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We consider a semiparametric regression model of a q-dimensional multivariate response y on a p-dimensional covariate x. In this paper, a new approach is proposed based on sliced inverse regression for estimating the effective dimension reduction (EDR) space without requiring a prespecified parametric model. The convergence at rate square root of n of the estimated EDR space is shown. We discuss the choice of the dimension of the EDR space. The numerical performance of the proposed multivariate SIR method is illustrated on a simulation study. Moreover, we provide a way to cluster components of y related to the same EDR space. One can thus apply properly multivariate SIR on each cluster instead of blindly applying multivariate SIR on all components of y. An application to hyperspectral data is provided.
multivariateSIR-2013.pdf (859.8 Ko) Télécharger le fichier
hal-00714981 , version 1 (06-07-2012)
hal-00714981 , version 2 (06-03-2013)
hal-00714981 , version 3 (05-10-2013)
  • HAL Id : hal-00714981 , version 2
Raphaël Coudret, Stéphane Girard, Jerome Saracco. A new sliced inverse regression method for multivariate response regression. 2013. ⟨hal-00714981v2⟩
737 Consultations
1075 Téléchargements
