Improved semidefinite branch-and-bound algorithm for k-cluster - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
This paper presents a method to solve k-cluster problems by intersecting semidefinite and polyhedral relaxations. We use a generic branch-and-bound method featuring an improved semidefinite bounding procedure. Extensive numerical experiments show that our algorithm outperforms the best known methods in both time and ability to solve large instances. For the first time, numerical results are reported for k-cluster problems on unstructured graphs with 140 and 160 vertices.
krislock-malick-roupin-2012a.pdf (258.17 Ko) Télécharger le fichier
hal-00717212 , version 1 (12-07-2012)
hal-00717212 , version 2 (13-07-2012)
hal-00717212 , version 3 (13-07-2012)
hal-00717212 , version 4 (13-07-2012)
hal-00717212 , version 5 (09-01-2014)
hal-00717212 , version 6 (06-02-2015)
  • HAL Id : hal-00717212 , version 2
Nathan Krislock, Jérôme Malick, Frédéric Roupin. Improved semidefinite branch-and-bound algorithm for k-cluster. 2012. ⟨hal-00717212v2⟩
861 Consultations
641 Téléchargements
