Anomalous versus slowed-down Brownian diffusion in the ligand-binding equilibrium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biophysical Journal Année : 2013
Measurements of protein motion in living cells and membranes consistently report transient anomalous diffusion (subdiffusion) which converges back to a Brownian motion with reduced diffusion coefficient at long times, after the anomalous diffusion regime. Therefore, slowed-down Brownian motion could be considered the macroscopic limit of transient anomalous diffusion. On the other hand, membranes are also heterogeneous media in which Brownian motion may be locally slowed-down due to variations in lipid composition. Here, we investigate whether both situations lead to a similar behavior for the reversible ligand-binding reaction in 2d. We compare the (long-time) equilibrium properties obtained with transient anomalous diffusion due to obstacle hindrance or power-law distributed residence times (continuous-time random walks) to those obtained with space-dependent slowed-down Brownian motion. Using theoretical arguments and Monte-Carlo simulations, we show that those three scenarios have distinctive effects on the apparent affinity of the reaction. While continuous-time random walks decrease the apparent affinity of the reaction, locally slowed-down Brownian motion and local hinderance by obstacles both improve it. However, only in the case of slowed-down Brownian motion, the affinity is maximal when the slowdown is restricted to a subregion of the available space. Hence, even at long times (equilibrium), these processes are different and exhibit irreconcilable behaviors when the area fraction of reduced mobility changes.
Soulaetal_2013.pdf (1.36 Mo) Télécharger le fichier
hal-00720515 , version 1 (24-07-2012)
hal-00720515 , version 2 (17-07-2013)
hal-00720515 , version 3 (17-07-2013)
  • HAL Id : hal-00720515 , version 2
Hédi Soula, Bertrand Caré, Guillaume Beslon, Hugues Berry. Anomalous versus slowed-down Brownian diffusion in the ligand-binding equilibrium. Biophysical Journal, 2013. ⟨hal-00720515v2⟩
459 Consultations
534 Téléchargements
