Goal-oriented error estimation for the reduced basis method, with application to sensitivity analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2016
The reduced basis method is a powerful model reduction technique designed to speed up the computation of multiple numerical solutions of parametrized partial differential equations. We consider a quantity of interest, which is a linear functional of the PDE solution. A new probabilistic error bound for the reduced model is proposed. It is efficiently and explicitly computable, and we show on different examples that this error bound is sharper than existing ones. We include application of our work to sensitivity analysis studies.
Rev_ArtGOErr.pdf (286.16 Ko) Télécharger le fichier
hal-00721616 , version 1 (28-07-2012)
hal-00721616 , version 2 (26-03-2013)
hal-00721616 , version 3 (10-07-2014)
Alexandre Janon, Maëlle Nodet, Clémentine Prieur. Goal-oriented error estimation for the reduced basis method, with application to sensitivity analysis. Journal of Scientific Computing, 2016, 68 (1), pp.21-41. ⟨10.1007/s10915-015-0127-z⟩. ⟨hal-00721616v3⟩
856 Consultations
542 Téléchargements
