Using Poisson processes to model lattice cellular networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
An almost ubiquitous assumption made in the stochastic-analytic study of the quality of service in cellular networks is Poisson distribution of base stations. It is usually justified by various irregularities in the real placement of base stations, which ideally should form the hexagonal pattern. We provide a different and rigorous argument justifying the Poisson assumption under sufficiently strong log-normal shadowing observed in the network, in the evaluation of a natural class of the typical-user service-characteristics including its SINR. Namely, we present a Poisson-convergence result for a broad range of stationary (including lattice) networks subject to log-normal shadowing of increasing variance. We show also for the Poisson model that the distribution of all these characteristics does not depend on the particular form of the additional fading distribution. Our approach involves a mapping of 2D network model to 1D image of it "perceived" by the typical user. For this image we prove our convergence result and the invariance of the Poisson limit with respect to the distribution of the additional shadowing or fading. Moreover, we present some new results for Poisson model allowing one to calculate the distribution function of the SINR in its whole domain. We use them to study and optimize the mean energy efficiency in cellular networks.
Poisson4.01.pdf (350.34 Ko) Télécharger le fichier
hal-00721994 , version 1 (31-07-2012)
hal-00721994 , version 2 (18-01-2013)
Bartlomiej Blaszczyszyn, Mohamed Kadhem Karray, Holger-Paul Keeler. Using Poisson processes to model lattice cellular networks. 2012. ⟨hal-00721994v1⟩
255 Consultations
273 Téléchargements
