Modeling Dynamic architectures using Dy-BIP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marius Bozga
Mohamad Jaber
  • Fonction : Auteur
  • PersonId : 880501
Nikolaos Maris
  • Fonction : Auteur
Joseph Sifakis
  • Fonction : Auteur
  • PersonId : 857859
Dynamic architectures in which interactions between components can evolve during execution, are essential for modern computing systems such as web-based systems, reconfigurable middleware, wireless sensor networks and fault-tolerant systems. Currently, we lack rigorous frameworks for their modeling, development and implementation. We propose Dy-BIP a dynamic extension of the BIP component framework rooted in rigorous operational semantics and supporting a powerful and high-level set of primitives for describing dynamic interactions. These are expressed as symbolic constraints offered by interacting components and computed efficiently by an execution Engine. We present experimental results which validate the effectiveness of Dy-BIP and show significant advantages over using static architecture models.
dy-bip.pdf (242.71 Ko) Télécharger le fichier
hal-00722481 , version 1 (02-08-2012)
Marius Bozga, Mohamad Jaber, Nikolaos Maris, Joseph Sifakis. Modeling Dynamic architectures using Dy-BIP. Software Composition - 11th International Conference, SC 2012, May 2012, Prague, Czech Republic. pp.1-16, ⟨10.1007/978-3-642-30564-1_1⟩. ⟨hal-00722481⟩
258 Consultations
501 Téléchargements
