Idempotents and the BCH bound - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 1994
Daniel Augot
  • Fonction : Auteur
  • PersonId : 833459
Nicolas Sendrier
Using a characterization of the idempotents of a narrow- sense primitive binary BCH code, we are able to give classes of such codes whose minimum distance does not exceed the BCH bound. Our results are compiled in a table.
idem.pdf (885.02 Ko) Télécharger le fichier
hal-00723735 , version 1 (13-08-2012)
Daniel Augot, Nicolas Sendrier. Idempotents and the BCH bound. IEEE Transactions on Information Theory, 1994, 40 (1), pp.204-207. ⟨10.1109/18.272483⟩. ⟨hal-00723735⟩
102 Consultations
246 Téléchargements
