Context-Aware Access Control for RDF Graph Stores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present SHI3LD, an access control framework for RDF stores. Our solution supports access from mobile devices with context-aware policies and is exclusively grounded on stan- dard Semantic Web languages. Designed as a pluggable filter for generic SPARQL endpoints, the module uses RDF named graphs and SPARQL to protect triples. Evaluation shows faster execution time for low-selective queries and less impact on larger datastores.
ECAI.pdf (611.9 Ko) Télécharger le fichier
hal-00724041 , version 1 (16-08-2012)
  • HAL Id : hal-00724041 , version 1
Luca Costabello, Serena Villata, Fabien Gandon. Context-Aware Access Control for RDF Graph Stores. ECAI - 20th European Conference on Artificial Intelligence - 2012, Aug 2012, Montpellier, France. ⟨hal-00724041⟩
499 Consultations
788 Téléchargements
