Change detection with synthetic aperture radar images by Wilcoxon statistic likelihood ratio test - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers change detection with multitemporal synthetic aperture radar (SAR) images. A novel statistical approach is developed that formulates the detection of changes between two coregistered SAR images acquired at different dates as a non-parametric local-window hypothesis testing problem. This approach takes into account the simultaneous testing of a large amount of similar hypotheses (i.e., one Wilcoxon test at each pixel of the image), and is based on a likelihood ratio test to obtain a detection map at the pixel level. Some encouraging detection results are obtained on XSAR and very high resolution COSMO-SkyMed images.
krylovICIP2012.pdf (1.1 Mo) Télécharger le fichier
hal-00724284 , version 1 (20-08-2012)
  • HAL Id : hal-00724284 , version 1
Vladimir Krylov, Gabriele Moser, Aurélie Voisin, Sebastiano B. Serpico, Josiane Zerubia. Change detection with synthetic aperture radar images by Wilcoxon statistic likelihood ratio test. IEEE International Conference on Image Processing 2012, Sep 2012, Orlando, United States. ⟨hal-00724284⟩
Collections
INRIA INRIA2
254 Consultations
689 Téléchargements
