Design of One Dimensional Digital IIR Filters using Orthogonal Polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Scholarly Research Notices Année : 2012
Vinay Kumar
In this paper we discuss the method of designing a zero or linear phase 1 Dimensional Infinite Impulse Response (IIR) filter using orthogonal polynomials. The approach is easy to understand and implement. Simulation results show the excellent performance of the proposed filter design technique.
IIRFILTER.pdf (150.59 Ko) Télécharger le fichier
hal-00724688 , version 1 (22-08-2012)
hal-00724688 , version 2 (18-10-2012)
Vinay Kumar, Sunil Bhooshan. Design of One Dimensional Digital IIR Filters using Orthogonal Polynomials. International Scholarly Research Notices, 2012, ISRN Signal Processing, Volume 2012 (2012), pp.1-7. ⟨10.5402/2012/870276⟩. ⟨hal-00724688v1⟩
59 Consultations
438 Téléchargements
