A hybridized discontinuous Galerkin method for 3d time-harmonic Maxwell's equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hybridized discontinuous Galerkin methods preserve the advantages of classical discontinuous Galerkin methods and in addition enable to circumvent the issue of the number of degrees of freedom. The principles of these numerical methods are summed up for 3d time-harmonic Maxwell's equations and basic examples are proposed to assess their efficiency.
Numelec2012_17.pdf (79.37 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00725079 , version 1 (23-08-2012)
  • HAL Id : hal-00725079 , version 1
Stéphane Lanteri, Liang Li, Ronan Perrussel. A hybridized discontinuous Galerkin method for 3d time-harmonic Maxwell's equations. NUMELEC, Jul 2012, Marseille, France. pp.18-19. ⟨hal-00725079⟩
219 Consultations
161 Téléchargements
