3D-model retrieval for Mobiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we present the FOX-MIIRE 3D-Model Search Engine. Our search engine is based on Adaptive Views Clustering (AVC) algorithm. The AVC method uses statistical model distribution scores to select the optimal number of views to characterize a 3D-model. The search engine also uses a probabilistic Bayesian method to retrieve 3D-models visually similar to a query 3D-model, photos or sketches. We present our results on the Princeton 3D Shape Benchmark database (1814 3D-models). Our 3D-model search engine is available on-line to assess and test our results. To our knowledge the FOX-MIIRE search engine is the first search engine that accepts 3D-models retrieval from photos. The FOX-MIIRE search engine adapts its own user interface de- pending on the web access device (desktop computer, PDA, SmartPhone).
acmcivr2007-final.pdf (552.05 Ko) Télécharger le fichier
hal-00725315 , version 1 (24-08-2012)
  • HAL Id : hal-00725315 , version 1
Tarik Filali Ansary, Jean-Philippe Vandeborre, Mohamed Daoudi. 3D-model retrieval for Mobiles. ACM International Conference on Image and Video Retrieval (CIVR), Jul 2007, France. pp.TechDemo. ⟨hal-00725315⟩
164 Consultations
223 Téléchargements
