3D-models recognition from a 2D sketch
This paper focuses on the recognition of simple polyhedral 3D-objects using a 2D hand-made sketch. In this method, both the objects to be recognized and the user sketch are represented by weighted graphs and indexed as a polynomial characterization of characteristic views in a hash-table.
