3D-models recognition from a 2D sketch - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
This paper focuses on the recognition of simple polyhedral 3D-objects using a 2D hand-made sketch. In this method, both the objects to be recognized and the user sketch are represented by weighted graphs and indexed as a polynomial characterization of characteristic views in a hash-table.
vandeborre_CESA98.pdf (153.75 Ko) Télécharger le fichier
hal-00725657 , version 1 (27-08-2012)
  • HAL Id : hal-00725657 , version 1
Jean-Philippe Vandeborre, Mohamed Daoudi, Christophe Chaillou. 3D-models recognition from a 2D sketch. CESA'98/IEEE IMACS Multiconference, Apr 1998, France. pp.529-532. ⟨hal-00725657⟩
158 Consultations
232 Téléchargements
