State-Dependent Sampling for Perturbed Time-Delay Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we present a state-dependent sampling control that allows for enlarging the sampling intervals of state-feedback control. We consider the case of perturbed linear time-invariant systems with input-delay and guarantee their L2-stability. The approach is based on a novel class of switched Lyapunov-Krasovskii functionals with state-dependent matrices. It results in an LMI problem that allows for enlarging the sampling interval according to the system state. Then, a mapping of the state space is designed offline: it computes for each state of the state space a lower-bound estimation of the maximum allowable sampling interval, which makes it possible to reduce the number of actuations during the real-time control of the system.
CDC_2012_-_Fiter_Hetel_Perruquetti_Richard.pdf (115.93 Ko) Télécharger le fichier
hal-00728437 , version 1 (06-09-2012)
  • HAL Id : hal-00728437 , version 1
Christophe Fiter, Laurentiu Hetel, Wilfrid Perruquetti, Jean-Pierre Richard. State-Dependent Sampling for Perturbed Time-Delay Systems. 51st IEEE Conference on Decision and Control, Dec 2012, Maui, Hawaï, United States. pp.CD. ⟨hal-00728437⟩
243 Consultations
184 Téléchargements
