On two multistable extensions of stable Lévy motion and their semimartingale representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We compare two definitions of multistable Lévy motions. Such processes are extensions of classical Lévy motion where the stability index is allowed to vary in time. We show that the two multistable Lévy motions have distinct properties: in particular, one is a pure-jump Markov process, while the other one satisfies neither of these properties. We prove that both are semimartingales and provide semimartingale decompositions.
Multistable_measure_and_processes.pdf (186.27 Ko) Télécharger le fichier
hal-00730680 , version 1 (10-09-2012)
hal-00730680 , version 2 (24-10-2013)
Ronan Le Guével, Jacques Lévy-Vehel, Lining Liu. On two multistable extensions of stable Lévy motion and their semimartingale representation. 2012. ⟨hal-00730680v1⟩
325 Consultations
244 Téléchargements
