Un modèle de trafic adapté à la volatilité de charge d'un service de vidéo à la demande: Identification, validation et application à la gestion dynamique de ressources. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Dynamic resource management has become an active area of research in the Cloud Computing paradigm. Cost of resources varies significantly depending on configuration for using them. Hence efficient management of resources is of prime interest to both Cloud Providers and Cloud Users. In this report we suggest a probabilistic resource provisioning approach that can be exploited as the input of a dynamic resource management scheme. Using a Video on Demand use case to justify our claims, we propose an analytical model inspired from standard models developed for epidemiology spreading, to represent sudden and intense workload variations. As an essential step we also derive a heuristic identification procedure to calibrate all the model parameters and evaluate the performance of our estimator on synthetic time series. We show how good can our model fit to real workload traces with respect to the stationary case in terms of steady-state probability and autocorrelation structure. We find that the resulting model verifies a Large Deviation Principle that statistically characterizes extreme rare events, such as the ones produced by "buzz effects" that may cause workload overflow in the VoD context. This analysis provides valuable insight on expectable abnormal behaviors of systems. We exploit the information obtained using the Large Deviation Principle for the proposed Video on Demand use-case for defining policies (Service Level Agreements). We believe these policies for elastic resource provisioning and usage may be of some interest to all stakeholders in the emerging context of cloud networking.
La gestion dynamique de ressources est un élément clé du paradigme de cloud computing et plus récemment de celui de cloud networking. Dans ce contexte d'infrastructures virtualisées, la réduction des coûts associés à l'utilisation et à la ré-allocation des ressources contraint les opé- rateurs et les utilisateurs de clouds à une gestion rationnelle de celles-ci. Dans ce travail nous proposons une description probabiliste des besoins liée à la volatilité de la charge d'un service de distribution de vidéos à la demande. Cette description peut alors servir de consigne (input) à la provision et à l'allocation dynamique des ressources nécessaires. Notre approche repose sur la construction d'un modèle stochastique inspiré des modèles de Markov standards de propaga- tion épidémiologique, capable de reproduire des variations soudaines et intenses d'activité (buzz). Nous proposons alors une procédure heuristique d'identification du modèle à partir de séries tem- porelles du nombre d'utilisateurs connectés au serveur. Les performances d'estimation de chacun des paramètres du modèle sont évaluées numériquement, et nous vérifions l'adéquation du modèle aux données en comparant les distributions des états stationnaires ainsi que les fonctions d'auto- corrélation des processus. Les propriétés markoviennes de notre modèle garantissent qu'il vérifie un principe de grandes dé- viations permettant de caractériser statistiquement l'ampleur et la durée d'évènements extrêmes et rares tels que ceux produits par les buzzs. C'est cette propriété que nous exploitons pour di- mensionner le volume de ressources (e.g. bande-passante, nombre de serveurs, taille de buffers) à prévoir pour réaliser un bon compromis entre coût de re-déploiement des infrastructures et qualité de service. Cette approche probabiliste de la gestion des ressources ouvre des perspectives sur les politiques de Service Level Agreement adaptées aux clouds et servant au mieux les intérêts des opérateurs de réseaux, de services et de leurs clients.
Roy-rr.pdf (1.03 Mo) Télécharger le fichier
hal-00734295 , version 1 (21-09-2012)
hal-00734295 , version 2 (01-10-2012)
Shubhabrata Roy, Thomas Begin, Paulo Gonçalves. Un modèle de trafic adapté à la volatilité de charge d'un service de vidéo à la demande: Identification, validation et application à la gestion dynamique de ressources.. [Research Report] RR-8072, 2012. ⟨hal-00734295v1⟩
Collections
INRIA-RRRT
288 Consultations
268 Téléchargements
