Improved CRT Algorithm for Class Polynomials in Genus~$2$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Damien Robert
We present a generalization to genus 2 of the probabilistic algorithm in Sutherland~\cite{Sutherland} for computing Hilbert class polynomial˻s. The improvement over the algorithm presented in~\cite{BGL} for the genus 2 case, is that we do not need to find a curve in the isogeny class with endomorphism ring which is the maximal order: rather we present a probabilistic algorithm for ''going up'' to a {\it maximal} curve (a curve with maximal endomorphism ring), once we find {\it any} curve in the right isogeny class. Then we use the structure of the Shimura class group and the computation of $(\ell,\ell)$-isogenies to compute all isogenous maximal curves from an initial one. This article is an extended version of the version published at ANTS~X.
Mots clés
writeuplong.pdf (545.37 Ko) Télécharger le fichier
hal-00734450 , version 1 (21-09-2012)
hal-00734450 , version 2 (17-04-2013)
  • HAL Id : hal-00734450 , version 1
Kristin Lauter, Damien Robert. Improved CRT Algorithm for Class Polynomials in Genus~$2$. ANTS X - Algorithmic Number Theory 2012, Jul 2012, San Diego, United States. Online publication. ⟨hal-00734450v1⟩
Collections
IRMAR
428 Consultations
153 Téléchargements
