Visualizing and Manipulating Automatic Document Orientation Methods Using Vector Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We introduce and illustrate a design framework whereby tabletop documents are oriented according to vector fields that can be visualized and altered by end users. We explore and illustrate the design space using interactive 2D mockups and show how this approach can potentially combine the advantages of the fully manual and fully automatic document orientation methods previously proposed in the literature.
vectorfields.pdf (832.65 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00734622 , version 1 (24-09-2012)
Pierre Dragicevic, Yuanchun Shi. Visualizing and Manipulating Automatic Document Orientation Methods Using Vector Fields. International Conference on Interactive Tabletops and Surfaces, Nov 2009, Banff, United States. pp.65-68, ⟨10.1145/1731903.1731918⟩. ⟨hal-00734622⟩
116 Consultations
197 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
