Efficient Bubble Enumeration in Directed Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Polymorphisms in DNA- or RNA-seq data lead to recognisable patterns in a de Bruijn graph representation of the reads obtained by sequencing. such patterns have been called mouths, or bubbles in the literature. They correspond to two vertex-disjoint directed paths between a source $s$ and a target $t$. Due to the high number of such bubbles that may be present in real data, their enumeration is a major issue concerning the efficiency of dedicated algorithms. We propose in this paper the first linear delay algorithm to enumerate all bubbles with a given source.
article15_spire.pdf (303.79 Ko) Télécharger le fichier
hal-00738927 , version 1 (05-10-2012)
Etienne E. Birmelé, Pierluigi Crescenzi, Rui Ferreira, Roberto Grossi, Vincent Lacroix, et al.. Efficient Bubble Enumeration in Directed Graphs. String Processing and Information Retrieval (SPIRE), Oct 2012, Cartagena, Colombia. pp.118-129, ⟨10.1007/978-3-642-34109-0_13⟩. ⟨hal-00738927⟩
380 Consultations
640 Téléchargements
