A tool for obtaining information on DTN traces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The applications for dynamic networks are growing every day, and thus, so is the number of studies on them. An important part of such studies is the generation of results through simulation and comparison with other works. We implemented a tool to generate information on a given network trace, obtained by building its corresponding evolving graph. This information is useful to help researchers choose the most suitable trace for their work, to interpret the results correctly and to compare data from their work to the optimal results in the network. In this work, we present the implementation of the DTNTES tool which provides the aforementioned services and use the system to evaluate the DieselNet trace.
Ferreira-ExtremeCom2012.pdf (394 Ko) Télécharger le fichier
hal-00742993 , version 1 (17-10-2012)
  • HAL Id : hal-00742993 , version 1
Alfredo Goldman, Paulo Floriano, Afonso Ferreira. A tool for obtaining information on DTN traces. 4th Extreme Conference on Communication (ExtremeCom 2012), Mar 2012, Zurich, Switzerland. pp.6. ⟨hal-00742993⟩
217 Consultations
134 Téléchargements
