A Formally-Verified C Compiler Supporting Floating-Point Arithmetic
Floating-point arithmetic is known to be tricky: roundings, formats, exceptional values. The IEEE-754 standard was a push towards straightening the field and made formal reasoning about floating-point computations possible. Unfortunately, this is not sufficient to guarantee the final result of a program, as several other actors are involved: programming language, compiler, architecture. The CompCert formally-verified compiler provides a solution to this problem: this compiler comes with a mathematical specification of the semantics of its source language (ISO C90) and target platforms (ARM, PowerPC, x86-SSE2), and with a proof that compilation preserves semantics. In this paper, we report on our recent success in formally specifying and proving correct CompCert's compilation of floating-point arithmetic. Since CompCert is verified using the Coq proof assistant, this effort required a suitable Coq formalization of the IEEE-754 standard; we extended the Flocq library for this purpose. As a result, we obtain the first formally verified compiler that provably preserves the semantics of floating-point programs.
