$V$-fold cross-validation and $V$-fold penalization in least-squares density estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
This paper studies $V$-fold cross-validation for model selection in least-squares density estimation. The goal is to provide theoretical grounds for choosing $V$ in order to minimize the least-squares risk of the selected estimator. We first prove a non asymptotic oracle inequality for $V$-fold cross-validation and its bias-corrected version ($V$-fold penalization), with an upper bound decreasing as a function of $V$. In particular, this result implies $V$-fold penalization is asymptotically optimal. Then, we compute the variance of $V$-fold cross-validation and related criteria, as well as the variance of key quantities for model selection performances. We show these variances depend on $V$ like $1+1/(V-1)$ (at least in some particular cases), suggesting the performances increase much from $V=2$ to $V=5$ or $10$, and then is almost constant. Overall, this explains the common advice to take $V=10$ ---at least in our setting and when the computational power is limited---, as confirmed by some simulation experiments.
penVFreech4.pdf (689.29 Ko) Télécharger le fichier
hal-00743931 , version 1 (22-10-2012)
hal-00743931 , version 2 (17-07-2014)
hal-00743931 , version 3 (09-10-2015)
Sylvain Arlot, Matthieu Lerasle. $V$-fold cross-validation and $V$-fold penalization in least-squares density estimation. 2012. ⟨hal-00743931v1⟩
803 Consultations
500 Téléchargements
