Test generation from recursive tiles systems
In this paper we explore test generation for Recursive Tile Systems (RTS) in the framework of the classical ioco testing theory. The RTS model al- lows the description of reactive systems with recursion, and is very similar to other models like Pushdown Automata, Hyperedge Replacement Grammars or Recursive State Machines. We first present an off-line test generation algorithm for Weighted RTS, a determinizable sub-class of RTS, and second, an on-line test generation algorithm for the full RTS model. Both algorithms use test purposes to guide test selection through targeted behaviours.
Mathématique discrète [cs.DM]
