Christiane's Hair - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The American Mathematical Monthly Année : 2013
Christiane's Hair
We explore the geometric and measure-theoretic properties of a set built by stacking central Cantor sets with continuously varying scaling factors. By using self-similarity, we are able to describe in a fairly complete way its main features. We show that it is made of an uncountable number of analytic curves, compute the exact areas of the gaps of all sizes, and show that its Hausdor and box counding dimension are both equal to 2. It provides a particularly good example to introduce and showcase these notions because of the beauty and simplicity of the arguments. Our derivation of explicit formulas for the areas of all of the gaps is elementary enough to be explained to rst-year calculus students.
The_CH_set_AMM.pdf (348.34 Ko) Télécharger le fichier
hal-00744268 , version 1 (22-10-2012)
Jacques Lévy Véhel, Franklin Mendivil. Christiane's Hair. The American Mathematical Monthly, 2013, 120 (9), pp.771-786. ⟨10.4169/amer.math.monthly.120.09.771⟩. ⟨hal-00744268⟩
238 Consultations
227 Téléchargements
