Convergent lower bounds for packing problems via restricted dual polytopes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Cutting-stock and bin-packing problems have been widely studied in the operations research literature for their large range of indus- trial applications. Many integer programming models have been proposed for them. The most famous is from Gilmore and Gomory [5] and relies on a column generation scheme. Column generation methods are known to have convergence issues, and (when minimizing) no useful lower bounds are produced before a possibly large number of iterations. We propose a new approach that converges to the optimum through a series of dual- feasible solutions, and therefore produces a series of iteratively improving lower bounds. Each dual-feasible solution is obtained by optimizing over an inner approximation of the dual polytope. This approximation is ob- tained by linking groups of dual variables by linear constraints, leading to a problem of smaller dimension. The inner approximation is iteratively refined by splitting the groups into smaller groups until an optimal dual solution is found.
main.pdf (211.95 Ko) Télécharger le fichier
hal-00747375 , version 1 (31-10-2012)
hal-00747375 , version 2 (16-12-2013)
  • HAL Id : hal-00747375 , version 1
Daniel Cosmin Porumbel, François Clautiaux. Convergent lower bounds for packing problems via restricted dual polytopes. 2012. ⟨hal-00747375v1⟩
586 Consultations
288 Téléchargements
