Towards Autonomic Multimodal Interaction
Heterogeneity and dynamism of pervasive environment prevent to build static multimodal interaction. In this paper, we present how we use the autonomic approach to build and maintain adaptable multi-modal interaction. We describes characteristic of adaptation, realized by an autonomic manager that relies on models specified by interaction designers and developers. Finally, an example with a real application and existing devices is explained.
Génie logiciel [cs.SE]
