Konio Pathway: An Instinctive Visual Mechanism for Survival and Decision Making?
Survival is one of the evolutionary priorities for every species on Earth. It is strongly linked to making good decisions, even if these are unconsciously made. In the visual system, interactions between conscious and unconscious processing have been discussed, depending on the main two information ows originating from the retina: the Parvo and Magno pathways. We consider here a possible role of the Konio pathway; less studied and with di erent characteristics, such as large receptive elds for global complex event detection, and di use projections which may allow to quickly inform several areas in the brain of something im- portant present in the visual world. To test these hypotheses, we developed a computational systemic model of the early visual system proposing one type of Konio cells, which respond to certain spectral patterns and change the dynamics of the rest of the system accordingly. When examining the model's responses to static inputs, we observe that the system exhibits desirable reactions, together with time cost and e ciency characteristics. We also discuss the implications of the hypotheses for more complete survival and decision making processes, as the Konio pathway may only be a foundation stone for them in terms of evolution.
La survie est l'une des priorités évolutives pour toutes les espèces sur la Terre. il est fortement liée à prendre les bonnes décisions, même si elles sont inconsciemment fait. Dans le système visuel, les interactions entre traitement conscient et inconscient ont été discutés, selon les deux principales informations ux en provenance de la rétine: les voies Parvo et Magno. Nous considérons ici un possible rôle de la voie Konio;? moins étudiées et avec di érentes caractéristiques, telles que grands champs récepteurs pour la détection événement mondial complexe et di? utiliser des projections ce qui peut permettre d'informer rapidement plusieurs zones dans le cerveau de quelque chose im- présente important dans le monde visuel. Pour tester ces hypothèses, nous avons développé un calcul modèle systémique du système visuel au début de proposer un type de Konio cellules qui répondent à certains modèles spectraux et changer la dynamique du reste du système en conséquence. Lors de l'examen des réponses du modèle à entrées statiques, nous observons que le système présente des réactions souhaitables, ainsi que avec des caractéristiques de coût et de temps e cacité?. Nous avons également discuter des implications des hypothèses de survie plus complet et le processus décisionnel, comme la voie Konio ne peut être qu'une première pierre pour eux en termes d'évolution.
Neurosciences
