Proceedings of the Third International Workshop on Model-driven High-level Programming of Embedded Systems (SLA++P) 2008 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2008
This report contains the proceedings of the Third International Workshop on Model-driven High-level Programming of Embedded Systems (SLA++P). SLA++P is a workshop dedicated to synchronous languages and the model-driven high-level programming of reactive and embedded systems.
1-s2.0-S1571066109001182-main.pdf (68.11 Ko) Télécharger le fichier
hal-00756597 , version 1 (23-11-2012)
  • HAL Id : hal-00756597 , version 1
Eric Rutten, Alain Girault. Proceedings of the Third International Workshop on Model-driven High-level Programming of Embedded Systems (SLA++P) 2008. SLA++P - Third International Workshop on Model-driven High-level Programming of Embedded Systems 2008, Apr 2008, Budapest, Hungary. ⟨hal-00756597⟩
174 Consultations
35 Téléchargements
