On the Discretization of Distance Geometry Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distance geometry consists of finding an embedding of a weighted undirected graph in R^n. Since some years, we are working on suitable discretizations for this problem. Because of the discretization, the search domain is reduced from a continuous to a discrete set which has the structure of a tree. Based on this combinatorial structure, we developed an efficient branch-and-prune (BP) algorithm for the solution of distance geometry problems. In this paper, we focus on two important aspects of the discretization: the identification of suitable vertex discretizing orderings and the analysis of the symmetries that can be found in BP trees.
Fichier non déposé
hal-00756945 , version 1 (24-11-2012)
  • HAL Id : hal-00756945 , version 1
Antonio Mucherino, Carlile Lavor, Leo Liberti, Nelson Maculan. On the Discretization of Distance Geometry Problems. Mathematics of Distances and Applications 2012 (MDA12), 2012, Varna, Bulgaria. ⟨hal-00756945⟩
283 Consultations
0 Téléchargements
