Oscillation annealing in Electronic Power Steering (EPS) systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
This document is a working report concerning the Task 5.1 of the project VolHand 09 VTT 14. This task is competence of the GipsaLab. This report presents several aspects of modelling, observation and control towards a new generation of Electrical Power Steering(EPS) systems. In particular authors design an optimal control to reject oscillations of the steering column. Authors also revisited the LuGre tire dynamic friction model by improving the transient behaviour between the sticking phases and the dynamic ones. Simulation of the proposed control are shown at the end of the document.
GIPSA_comp.pdf (280.98 Ko) Télécharger le fichier
hal-00757000 , version 1 (26-11-2012)
  • HAL Id : hal-00757000 , version 1
Valentina Ciarla, Carlos Canudas de Wit, Franck Quaine, Violaine Cahouet. Oscillation annealing in Electronic Power Steering (EPS) systems. [Research Report] GIPSA-lab. 2011. ⟨hal-00757000⟩
424 Consultations
291 Téléchargements
