Exogenous input estimation in Electronic Power Steering (EPS) systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
This document is a working report concerning the Task 5.1 of the project VolHand 09 VTT 14. This task is competence of the GipsaLab. This report presents several aspects of modelling, observation and control towards a new generation of Electrical Power Steering(EPS) systems. In particular authors design an observer to estimate the driver's applied torque (steering wheel torque) and the load torque (tire/ground contact friction). Simulation of the proposed control and observer are shown at the end of the document.
GIPSA_obs.pdf (70.7 Ko) Télécharger le fichier
hal-00757001 , version 1 (26-11-2012)
  • HAL Id : hal-00757001 , version 1
Valentina Ciarla, Carlos Canudas de Wit, Franck Quaine, Violaine Cahouet. Exogenous input estimation in Electronic Power Steering (EPS) systems. [Research Report] GIPSA-lab. 2011. ⟨hal-00757001⟩
245 Consultations
145 Téléchargements
