Long-Time Stability Analysis of Acoustic Absorbing Boundary Conditions for Regular-Shaped Surfaces
This work deals with the stability analysis of a one-parameter family of Absorbing Boundary Conditions (ABC) that have been derived for the acoustic wave equation. We tackle the problem of long-term stability of the wave field both at the continuous and the numerical levels. We first define a function of energy and we show that it is decreasing in time. Its discrete form is also decreasing under a Courant-Friedrichs-Lewy (CFL) condition that does not depend on the ABC. Moreover, the decay rate of the continuous energy can be determined: it is exponential if the computational domain is star-shaped and this property can be illustrated numerically.
