Modular termination of C programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
In this paper we describe a general method to prove termination of C programs in a scalable and modular way. The program to analyse is reduced to the smallest relevant subset through a termination-specific slicing technique. Then, the program is divided into pieces of code that are analysed separately, thanks to an external engine for termination. The result is implemented in the prototype \stoptool over our previous toolsuite WTC [compsys-termination-sas10] and preliminary results shows the feasibility of the method.
RR-8166.pdf (673.59 Ko) Télécharger le fichier
hal-00760917 , version 1 (04-12-2012)
hal-00760917 , version 2 (19-12-2012)
  • HAL Id : hal-00760917 , version 1
Andrieu Guillaume, Christophe Alias, Laure Gonnord. Modular termination of C programs. [Research Report] RR-8166, 2012. ⟨hal-00760917v1⟩
Collections
LIFL
333 Consultations
163 Téléchargements
