Recovering people tracking errors using enhanced covariance-based signatures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a new approach for tracking multiple persons in a single camera. This approach focuses on re- covering tracked individuals that have been lost and are detected again, after being miss-detected (e.g. occluded) or after leaving the scene and coming back. In order to correct tracking errors, a multi-cameras re-identification method is adapted, with a real-time constraint. The proposed ap- proach uses a highly discriminative human signature based on covariance matrix, improved using background subtrac- tion, and a people detection confidence. The problem of linking several tracklets belonging to the same individual is also handled as a ranking problem using a learned pa- rameter. The objective is to create clusters of tracklets de- scribing the same individual. The evaluation is performed on PETS2009 dataset showing promising results.
4797a487.pdf (387.47 Ko) Télécharger le fichier
hal-00761322 , version 1 (05-12-2012)
Julien Badie, Slawomir Bak, Silviu-Tudor Serban, François Bremond. Recovering people tracking errors using enhanced covariance-based signatures. Fourteenth IEEE International Workshop on Performance Evaluation of Tracking and Surveillance - 2012, Jul 2012, Beijing, China. pp.487-493, ⟨10.1109/AVSS.2012.90⟩. ⟨hal-00761322⟩
Collections
INRIA INRIA2
138 Consultations
162 Téléchargements
