Correction to "Estimation of errors in the inverse modeling of accidental release of atmospheric pollutant: Application to the reconstruction of the cesium-137 and iodine-131 source terms from the Fukushima Daiichi power plant" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research: Atmospheres Année : 2012
Correction to "Estimation of errors in the inverse modeling of accidental release of atmospheric pollutant: Application to the reconstruction of the cesium-137 and iodine-131 source terms from the Fukushima Daiichi power plant,"
winiarek2012b.pdf (70.72 Ko) Télécharger le fichier
hal-00761575 , version 1 (13-11-2013)
Victor Winiarek, Marc Bocquet, Olivier Saunier, Anne Mathieu. Correction to "Estimation of errors in the inverse modeling of accidental release of atmospheric pollutant: Application to the reconstruction of the cesium-137 and iodine-131 source terms from the Fukushima Daiichi power plant". Journal of Geophysical Research: Atmospheres, 2012, 117 (D18118), ⟨10.1029/2012JD018107⟩. ⟨hal-00761575⟩
176 Consultations
327 Téléchargements
