Stochastic receding horizon control with output feedback and bounded controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2012
We study the problem of receding horizon control for stochastic discrete-time systems with bounded control inputs and incomplete state information. Given a suitable choice of causal control policies, we first present a slight extension of the Kalman filter to estimate the state optimally in mean-square sense. We then show how to augment the underlying optimization problem with a negative drift-like constraint, yielding a second-order cone program to be solved periodically online. We prove that the receding horizon implementation of the resulting control policies renders the state of the overall system mean-square bounded under mild assumptions. We also discuss how some quantities required by the finite-horizon optimization problem can be computed off-line, thus reducing the on-line computation.
Stochastic_receding_horizon_control_with_output_feedback_and_bounded_controls.pdf (349.23 Ko) Télécharger le fichier
hal-00762600 , version 1 (07-12-2012)
Peter Hokayem, Eugenio Cinquemani, Debasish Chatterjee, Federico Ramponi, John Lygeros. Stochastic receding horizon control with output feedback and bounded controls. Automatica, 2012, 48 (1), pp.77-88. ⟨10.1016/j.automatica.2011.09.048⟩. ⟨hal-00762600⟩
191 Consultations
866 Téléchargements
