TEI and LMF crosswalks
The present paper explores various arguments in favour of making the Text Encoding Initia-tive (TEI) guidelines an appropriate serialisation for ISO standard 24613:2008 (LMF, Lexi-cal Mark-up Framework) . It also identifies the issues that would have to be resolved in order to reach an appropriate implementation of these ideas, in particular in terms of infor-mational coverage. We show how the customisation facilities offered by the TEI guidelines can provide an adequate background, not only to cover missing components within the current Dictionary chapter of the TEI guidelines, but also to allow specific lexical projects to deal with local constraints. We expect this proposal to be a basis for a future ISO project in the context of the on going revision of LMF.
Informatique et langage [cs.CL]
TEI_and_LMF_crosswalks.pdf (1.17 Mo)
Télécharger le fichier
LMFSyntax.rnc (127.81 Ko)
SyntaxExtension.xml (4.32 Ko)
syntacticFrame.xml (1.35 Ko)
Format : Autre
Format : Autre
Format : Autre
